| | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 16 New Guy | | New Guy Joined: Jul 2013 Posts: 16 | My '51 generator is not charging.
I have 2 posts on my generator. With truck running, both posts at generator have 0 Volts when checking to ground.
My voltage regulator has 5.5V at the left terminal, 0V on the right and middle. I believe the right post is the F terminal, and the middle should be the B+ coming off of the generator?
Thanks in advance, Keith
1951 3600 Chevrolet
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the left post is BATT, middle is GEN [or ARM], right is Field .... the shop manual has info for the charging system, and there's a pamphlet all about itBill | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Start out by "polarizing" the generator. Take a short jumper wire and touch it to the Bat and Arm terminals on the regulator quickly, about 1/2 second or so. A pretty good arc is normal. This puts a weak magnetic field in the generator housing and makes it produce about .5 volts DC at the Armature terminal. This voltage is sufficient to energize the field coils which find a ground at the regulator and increase the strength of the magnetic field in the generator housing. If the regulator is working properly, the voltage should rise to around 6.5 volts and close the set of regulator points behind the Bat. terminal.
If the generator cannot be polarized, you probably need some repair/rebuilding work done inside the generator. If the generator produces the .5 volts at the armature terminal after polarizing, but will not go higher, try cleaning the regulator points with a piece of clean index card stock or a business card. (No filing or sandpaper!) Disconnect the BAT wire at the regulator first, to avoid shorting anything out while working on the regulator. Good luck! Jerry
| | | | | Joined: Jul 2013 Posts: 16 New Guy | | New Guy Joined: Jul 2013 Posts: 16 | Start out by "polarizing" the generator. Thanks-this is what I was leaning toward. This should be done with the engine running-correct? This truck has been sitting since 1981 so I am wondering if the "field" was lost while it sat.. Thanks, Keith
1951 3600 Chevrolet
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | before starting the engine
Bill | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Running- - - -not running - - - - -doesn't really matter. I've done it both ways for over 50 years with no noticeable difference in the results- - - -it either works or not depending on the internal capability of the generator. I am partial to using an "analog" volt/amp meter, (with a sweep needle) as some digital meters respond too fast for a vibrating contact regulator and just end up indicating gibberish instead of a usable indication of current or voltage. Jerry
