5 members (PAUL Berardi, Bill Hanlon, Otto Skorzeny, moparguy, DaveV), 127 guests, and 1 robot.
Topics128,111
Posts1,056,244
Members48,437
The drums on my 1/2 ton '49 Chev panel need to be cut. NAPA and another store will not touch them because they have no maximum/minimum numbers stamped on them.
What, if any, is the fix?? Anyone know what the minimum thickness is or
the maximum i.d. is for these old drums??
Any help or guidance appreciated.
1 1951 Chev Panel with a 350 small block, automatic tranny.
1 2004 Chev 2500 HD pickup... stock
1 1950 Chev 5 window pickup; 261 c.i. engine, 4 on the floor.
With lots of time and money, any Stovebolt can be restored.
3B Offline
Hy Jerry Bubolz, welcome, light truck drums should not be turned more than .060" over their standard size, hope that helps.
Any shop that turns drums should have a drum mic.
I think 10 thousandths over is the limit. Could be wrong on that.
Ed
Thanks Shop Shark, Marty and Ed.
I've got the '48 to '53 Chevrolet Truck Shop Manuel. I guess what I need to give to NAPA or any shop that will attempt to rebore the drums is the "standard
diameter" of a new drum. With this information the shop can measure the inside diameter of my drums with a micrometer and determine if there is enough metal
left on my drums that can be rebored without going over .060 oversize.
If that information is in the shop manual, I've been unable to find it. Since no figures are stamped on the drum, the shops won't touch 'em. And, I guess, for
safety reasons I don't want the drums rebored outside of limits.
Meant 3B, not Shop Shark.
3B Offline
Hy Jerry Bubolz, the standard size of half ton drums in 1949 is 11", hope that helps.
Thanks for the confirmation of the 11" standard. Just now I went out and measured one of my drums. I don't have an inside mike but I'll bet $1 that
the i.d. of these old drums are way over the 11" plus .060 allowable re-bore.
I'll take the drums into NAPA tomorrow and let them measure.
Thanks for the help 3B.
