1 members (Hotrod Lincoln),
69
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 120 'Bolter | | 'Bolter Joined: Sep 2014 Posts: 120 | The drums on my 1/2 ton '49 Chev panel need to be cut. NAPA and another store will not touch them because they have no maximum/minimum numbers stamped on them. What, if any, is the fix?? Anyone know what the minimum thickness is or the maximum i.d. is for these old drums?? Any help or guidance appreciated. Jerry
1 1951 Chev Panel with a 350 small block, automatic tranny. 1 2004 Chev 2500 HD pickup... stock 1 1950 Chev 5 window pickup; 261 c.i. engine, 4 on the floor.
With lots of time and money, any Stovebolt can be restored.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jerry Bubolz, welcome, light truck drums should not be turned more than .060" over their standard size, hope that helps. | | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | Any shop that turns drums should have a drum mic. I think 10 thousandths over is the limit. Could be wrong on that. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 |
Ed
| | | | | Joined: Sep 2014 Posts: 120 'Bolter | | 'Bolter Joined: Sep 2014 Posts: 120 | Thanks Shop Shark, Marty and Ed. I've got the '48 to '53 Chevrolet Truck Shop Manuel. I guess what I need to give to NAPA or any shop that will attempt to rebore the drums is the "standard diameter" of a new drum. With this information the shop can measure the inside diameter of my drums with a micrometer and determine if there is enough metal left on my drums that can be rebored without going over .060 oversize. If that information is in the shop manual, I've been unable to find it. Since no figures are stamped on the drum, the shops won't touch 'em. And, I guess, for safety reasons I don't want the drums rebored outside of limits. Jerry
| | | | | Joined: Sep 2014 Posts: 120 'Bolter | | 'Bolter Joined: Sep 2014 Posts: 120 | Meant 3B, not Shop Shark.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jerry Bubolz, the standard size of half ton drums in 1949 is 11", hope that helps. | | | | | Joined: Sep 2014 Posts: 120 'Bolter | | 'Bolter Joined: Sep 2014 Posts: 120 | Thanks for the confirmation of the 11" standard. Just now I went out and measured one of my drums. I don't have an inside mike but I'll bet $1 that the i.d. of these old drums are way over the 11" plus .060 allowable re-bore. I'll take the drums into NAPA tomorrow and let them measure. Thanks for the help 3B. Jerry
