1 members (dt235sd),
122
0
Mod | | | Forums66 Topics128,151 Posts1,056,997 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Hello All,
I recently purchased a 1950 GMC 350 series.
But when I went to register it found that the title and vehicle numbers do not match.
Info from door tag... GMC Year Model: 1950 Series: 350 Model Number: FC 354 Serial Number 22498 GVW: 13500
Info on title... GMC Year Model: 1950 Model Number: DRF64450 GVW: 09650
What does the code numbers mean...DRF64450, circa 1950 GMC.
I could not find these anywhere.
Oh yeah, it (the truck) is also registered as a Van..pardon me but did GMC build a Van in 1950?
And isn't 09650 weight closer to a 1 ton than a 2 ton?
Further info it has a 14 foot flatbed with dump hoist. And was used by Southern Pacific Railroad for about 10 to 15 years out of Oroville CA. and Quincy CA.
Ant ideas or help is appreciated.
Thanx,
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes there were "vans" in 1950, called panel trucks back then, but most jurisdictions don't have that category anymore, or maybe the truck originally had some kind of 3rd party box body rather than a flat deck - or you may have a title that was not originally for that truck  most areas in 1950 used the engine number to register vehicles rather than the mfgrs ID [vin], so the DRF may have been that - isn't there a "vin" line on the title? Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That isn't a GMC engine serial number. It may be a Chevy number but I don't have access to my reference to look it up right now.
Sounds like you got a title for a 1-ton panel truck that had the engine changed and the title changed to match the replacement engine. The door jamb tag shows a 2-ton truck. | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Hi,
The VIN on title is: DRF64450
I found a lot of the old CA registrations in the glove box.
They all show the same thing.
The person who had the truck before has since past-away so no going back to him.
I am thinking may be one of 2 possible scenarios, one he was using a bogus tile, or he lost the right tile and substituted this one. Either way I have an interesting situation.
The person I bought the truck from is going to apply for a lost tile.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | more likely that number is the engine number, commonly used as the title vin back then, check for an engine number - if the engine has been changed the title should have been changed at the same time, although most folks didn't bother to do that
Bill | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | GMCs did not use letters in engine numbers back then, in fact the first 3 digits were the engine size.
I already checked the engine numbers: 248XXXXX
And some engine numbers were repeated each year.
Serial numbers were not much of an issue 65 years ago.
| | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | FYI....only the registered owner can apply for a lost title. If the guy you bought it from had his name on the title then it's pretty easy. If not, then it gets more difficult. And if the numbers on the title don't match the numbers on the truck, then that title is useless anyway.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Regarding use of letters in GMC engine serial "numbers" back then. GMC did often use a a one-letter prefix in the engine serial number (located in front of the engine size). The pre-fix was used to designate that the installed engine had non-standard-sized cylinder bore and/or crankshaft journals. The GMC documentation incorrectly stated that the letter was a suffix on the engine serial number - it was a prefix.
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | He is the registered owner of record.
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Well I have 7 GMC engines from 228s to 302s none have Letters in the serial numbers.
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | If I understand correctly, if the engines was altered or factory repaired they added a letter preceding the engine numbers.
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Question again, Did Canadian manufactured GMC trucks have a different type/style numbering system?
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | 13500 lb. gvw doesn't sound right for a 350 seriesa 2 ton. Should be 16000lb. gvw for 350 series. Got any pictures you can post of it? | | |
