2 members (Gray_Ghost, Joe W),
211
Mod | | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 52 | I would like to I.D. my 3 spd trans on my 61 Apache. The internet says there should either be for Example(M503 for Muncie or S503 for Saginaw)stamped somewhere on the trans. I have found other markings but not those. Can someone tell me where on the trans these markings will be? I replaced the speedo cable on my truck(old one was snapped in half). The speedometer is still not working. Is there a speedo gear in the trans that can be replaced w/o taking the trans apart? Could the problem be in the Speedometer head itself? Thank you | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | click 'Show' at "Chevrolet Trucks (All Models Not Listed Below)", and download the '61 PDF to learn a lot about your truck - won't specify maker of trans, but unlikely you have a Saginaw unless someone replaced the original, the Saginaw [all syncro] started about 1967 yes, the speedo head could be gummed up or broken, more likely than the drive gear being gone in the trans, but that can be checked by unhooking the cable at the speedo and driving it while feeling if the cable turns Bill | | | | | Joined: Aug 2014 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 52 | I unhooked the speedo cable from the back of the speedo head and found that the cable does turn while driving, so that tells me the problem is in the speedo head. First question, I took the screws out for the instrument cluster but am unable to pull it out from the front of the dash, is there a trick to this? (no wires are holding it in) Can you repair a speedo head yourself, if not where would I get it repaired? | | |
