1 members (RLB), 119 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
I would like to I.D. my 3 spd trans on my 61 Apache. The internet says there should either be for Example(M503 for Muncie or S503 for Saginaw)stamped somewhere on the trans. I have found other markings but not those. Can someone tell me where on the trans these markings will be?
I replaced the speedo cable on my truck(old one was snapped in half). The speedometer is still not working. Is there a speedo gear in the trans that can be replaced w/o taking the trans apart? Could the problem be in the Speedometer head itself?
Thank you
click 'Show' at "Chevrolet Trucks (All Models Not Listed Below)", and download the '61 PDF to learn a lot about your truck - won't specify maker of trans, but unlikely you have a Saginaw unless someone replaced the original, the Saginaw [all syncro] started about 1967
yes, the speedo head could be gummed up or broken, more likely than the drive gear being gone in the trans, but that can be checked by unhooking the cable at the speedo and driving it while feeling if the cable turns
I unhooked the speedo cable from the back of the speedo head and found that the cable does turn while driving, so that tells me the problem is in the speedo head. First question, I took the screws out for the instrument cluster but am unable to pull it out from the front of the dash, is there a trick to this? (no wires are holding it in)
Can you repair a speedo head yourself, if not where would I get it repaired?
