0 members (),
86
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 52 | Hello, I am unsure of what kind of rear end I have in my newly acquired 61 apache, and if it is original or not. I took pictures but do not know how to attach them to this post. The numbers stamped on it are MA 10 04. From what I can find from the internet MA is abase axle C14,built 10 month 04 day of the month. Is a C14 the same as a C10? The reason I question this rear end is, I am trying to purchase parking brake cables for this truck(currently there is only the front one which is rusted)and all pictures that I have seen of new rear cables look like the cable is attached to the backing plate with possibly two bolts , where my backing plate only has the one large hole in it. Can someone please give me some direction? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just from the codes you've posted, it sounds like you have the HO33 axle with the 3.90 gear ratio.
Bill Burmeister | | |
