| | | Forums66 Topics128,268 Posts1,058,391 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 30 Junior Member | | Junior Member Joined: Oct 2003 Posts: 30 | HI EVERYONE ...i have a question...I'm into the interior now ...i took the seat out and the base does not seem to be bolted in ...is the seat base tacked into place ?? I can't even seem to find tacks ...trying to find out before i cut it out to redo the floor ....many thanks.........gary | | | | | | Anonymous Unregistered | | Anonymous Unregistered | The seat base is secured using spot welds. I would guess there are about 30 holding it down. If you are trying to save the base then you will have to drill each one out. If you are not going to use the stock seat then the hot wrench works good to remove the majority and then a grinder can be used on the welds. Plan for a full day of fun. | | |
