9 members (Gray_Ghost, DaveV, Gdads51, EchoBravoSierra, Goach2, Ponchogl, Sjm, Joe H, 1 invisible), 76 guests, and 5 robots.
Topics128,268
Posts1,058,391
Members48,485
#105465 11/02/2004 3:41 AM
Junior Member
Junior Member
HI EVERYONE ...i have a question...I'm into the interior now ...i took the seat out and the base does not seem to be bolted in ...is the seat base tacked into place ?? I can't even seem to find tacks ...trying to find out before i cut it out to redo the floor ....many thanks.........gary
#105466 11/02/2004 4:49 AM
Anonymous
Unregistered
Anonymous
Unregistered
The seat base is secured using spot welds. I would guess there are about 30 holding it down. If you are trying to save the base then you will have to drill each one out. If you are not going to use the stock seat then the hot wrench works good to remove the majority and then a grinder can be used on the welds. Plan for a full day of fun.
