| | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 2 Moderated | | Moderated Joined: Apr 2013 Posts: 2 | Hi Can someone tell me how to set the oil dipper height on my 216 rebuild ? Tom | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | At one time, there was a factory fixture used to check the position of the dipper in relation to the troughs in the oil pan, but they're scarce as a chicken with lips these days. A couple of framing squares and a string can be used to measure the height of the dippers above the oil pan rails, then a measurement can be taken from the pan flange to the troughs to see if the measurements correspond. It's a little time-consuming, but necessary if you have any doubts about the dipper/trough interface.
Another important measurement is the spray pattern of the oil from the pipes alongside the edge of the pan. Scribe an "X" directly across from each nozzle and attach a water hose to the supply tube. The water stream should hit the center of the X- - - -if not, bend the pipes until they do. At speeds above idle, the oil sprays directly into the dippers due to increased volume from the oil pump. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
