| | | Forums66 Topics128,130 Posts1,056,717 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 28 Junior Member | | Junior Member Joined: Jan 2002 Posts: 28 | I'm trying to find out if a 55-59 OEM Chevy/GMC turn signal option will fit on my 50 GMC column. I don't have the turn signal assembly in hand so can't do a fit check but the picture of one looks like it could easily be adapted. Anyone know???
Grant 50 GMC 45 Burb | | | | | Joined: Jul 2003 Posts: 85 Member | | Member Joined: Jul 2003 Posts: 85 | my 44 chevy column has a turn signal adapter from the 50's, but I don't know what year the signal came from.. it's the arrow blinkers, and the piece on the column is a rectangle with rounded corners and a little throw lever... I don't have a picture of that part on my truck...
does this sound like what you are talking about?
-Mike R. | | | | | Joined: Jan 2002 Posts: 28 Junior Member | | Junior Member Joined: Jan 2002 Posts: 28 | The one began production as a assesory in late 54 and is a cup style configuration with the switching inside the cup that fits on the column shaft at the top of the column tube just below the steering wheel. It looks like a OEM part, not the clamp on type sold by aftermarket vendors. | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | I have the factory turn signal on my 57. I would think it would work on any column of the same diameter. Sorry, I dont know what that measurement is. Keep in mind that there is a raised area at 12 o'clock on the column that the assembly slides over to keep it from rotating on the column.(if I recall correctly). I guess you could fabricate something. I've been wanting to rebuild mine, do you know of a vendor who sells parts for these? If not I might be interested in replacing the whole assembly. And the cancelling ring is on the back of the steering wheel. I hope this helps. Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Jan 2002 Posts: 28 Junior Member | | Junior Member Joined: Jan 2002 Posts: 28 | jmoore, try jim carters and chevy duty. I beleive they have the parts you need....Grant | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Grant, I thought I had checked them both in the past but I will check again. Thanks for the tip. Jeff
1957 GMC 150
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the steering wheel is the same from 54 to 56 I believe, and the TF turn signal cup fits all 55-59, so it might work on earlier columns if the canceling ring can be fitted to the earlier wheel - the canceling ring, the actual switch w/ wires, and the small wedge piece that holds the cup tight on the column are all available at most any supplier - as well as the handle w/ knob - all ya gotta find is the cup
I could take any measurements ya want Grant, and pictures, as I've got a number of the TF units in the parts boxes
Bill | | | | | Joined: Jan 2002 Posts: 28 Junior Member | | Junior Member Joined: Jan 2002 Posts: 28 | Actually, the one I ran across is for sale at Jim Carter's web site as a used part (garage sale item). I beleive it is a 57 to 59 and the price looks right. I've decided to hold off on mine for now since I have more pressing items to work than a turn signal. My left arm is still in realatively good condition for signaling! HA! But eventuallu I would like to have a more OEM style than the usual clamp on type.... | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Grant, Originally the clamp on style, "Guide 6004 Directional Signal" kit, was all that was availabe, on '47-'53 trucks, & some earlier cars. I've seen alot of '47-'53 G.M. trucks outfitted with the, "Signal Stat' clamp on kit also. Most of my GMC, & Chevrolet accessory Info. points to the Guide set. I like them best, because I think the glass lens Guide Directionals look "COOL". Is your truck a pickup, or big truck. | | |
