0 members (),
68
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | After re-building a donor carb,and replacing the cab-to-frame line,as well as the fuel pump,(frame) feed line, "'Mo'Tater" is up and running again! I primed the carb,and it started right up,and kept idling!! I connected the vacuum gauge to the line from the intake manifold to the hydrovac,and adjusted the fuel/air mix. It's dead-center in the "green"! no more vacuum leak!! It must've been something with the original carb. I still had the timing light hooked-up.and with a 1/16th turn of the dizzy,"she's" right on the mark! Now I know why I installed the H.E.I.-you barely touch the stomp--and "She's" purrin' like a kitten!! I drove it to the gas station,(about dusk),and "there's no "hitch to this git-along"! Runs GREAT!! Good News Good News!! Love It!! Hope Y'All had a GOOD day,as well!!
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy wetwilly5757, I'm very glad you had a good day, I hope you have many more! | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Thanks,3B!! Same to you,Kind Sir!! | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Way to hang in there Willy...I know it feels good to have the monkey off your back and thing working as they should! Congrats! Mike B  | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Thanks,Mike!! That vacuum leak was driving me BATTY!! That different carb,(off a truck that sat for 30 years),made all the difference in the world!! This is the BEST it has run,since I owned the truck! Got off work tonight,and it's about 55 degrees. I pulled the choke,one pump on the gas,hit the stomp,and INSTANT start!! "It doesn't get any better than this"!! HOO YA!! | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | It's always a good feeling when you figure out how to kill a gremlin isn't it. Good job.
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | What brand HEI dizzy did you buy and where did you buy it from?
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Thank-you for the kind words,Tiny!! Spotbiltxo,I bought it from a guy on E-Bay."SwapmeetParts" (100% customer satisfaction Rating)!!. One year Warranty. There's no name on it,(distributor), that I can see,but it works well,and came with everything for a quick,professional installation.Has a connection for tach,as well Vacuum-advance..Seller is VERY HELPFUL!! Only problem is, the mounting gasket leaks. There's a split in the base,for timing,that gets tightened with an Allen wrench. I had to gob Permatex in the crack,to keep my fresh yellow paint from getting stained. Hopefully it will hold until the next tune-up. Brand new unit for about $160.00/FREE SHIPPING!!
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Speaking of swap meets, I bought an HEI at the Pate Swap back in April. Brand new. Paid $55 for it. Thought it was a good deal. It's the large diameter style. Have seen some that are much smaller like original distributors. Bought it to put in a 350 V8 when I do then conversion on the '51 half ton but might buy another to put in the 216 six in my '50. It's all original and I thought since your engine ran so well with one it might be worth the effort to put one in mine. You were very enthusiastic!
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | I bought mine back in March,and the price was $198.00. It is the large diameter style,(6 cylinder),but now the price is reduced to $159.00! even with the (fixed), oil leak,the starter will last much longer,since it starts immediately,instead of cranking for a minute or two. Better performance,as well. I haven't checked the fuel mileage,yet,but should see a positive change there,as well. I helped a friend install a Petronix unit,on a '59 Viking 60 bus. It,too,has a 261. It hasn't run good since. Starts hard,3-5 minutes of cranking,and doesn't perform well. Rough idle,as well as no power during acceleration.0-45 in about 4-5 minutes!! He's planning on purchasing a H.E.I.,as well.
