Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (2-Ton, 55shaker, cmayna, Hotrod Lincoln, CuzzFuzz, jmoore, Bill Hanlon), 49 guests, and 2 robots.
Topics128,018
Posts1,055,259
Members48,417
#1054199 09/05/2014 11:44 AM
1954 3100
Got my shift lever freed up last night and reinstalled. Seems to be working pretty good now. Next issue is to get rid of all the slack in the linkage. Does someone make a kit with all the grommets, springs,washers etc? I searched LMCs catalog and didn't find anything as far as linkage.
Don't think you will find the linkage being reproduced by anyone, However the bushings and washers are available at most of the companies that sell parts. May even be available at napa.
Tommy
59 apache 1/2t
261 short stepside
I don't need the linkage....I was just searching for linkage to find the related hardware. I didn't find anything at LMC or I wasn't looking in the right place.
Update....I found the bushings.
I made my own 'Arm' bushings using 1/4 inch ID High Pressure Fuel Hose, and used a Single Edge Razor Blade to neatly cut these to length.
And I found suitable small short Coil Springs, Washers and Cotter Pins at a local True Value Hardware Store.
