| | | Forums66 Topics128,066 Posts1,055,874 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 15 New Guy | | New Guy Joined: Oct 2011 Posts: 15 | Can anyone tell me how to tighten up my steering on my 52 chev 1/2 ton PU. All bushings and ball joints have been replaced. I understand there is some adjustment to the steering gear box. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | FWIW, I rebuilt/restored entire front end and steering box and the steering on my truck is decent, but I would not call it tight. I don't ever think you are going to get steering feel comparable to more modern vehicles unless upgraded equipment is employed. | | | | | Joined: May 2005 Posts: 85 Shop Shark | | Shop Shark Joined: May 2005 Posts: 85 | Hi Green52,
Years ago I rebuilt the stock front suspension on my '56, tie rod ends, king pins, pitman arm, everything in an attempt to fix sloppy steering. Didn't really help much. Finally I adjusted the steering box and the difference was night and day. The other big improvements to handling were addition of a front sway bar and leaf spring liners.
Would have to agree with DavidF that it may never be as precise as a more modern vehicle but I can take my hands off the wheel at freeway speeds and it doesn't wander at all. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I just did the adjustment on my '56 last week. For years I have put up with sloppy steering and finally got around to it. What a difference. Also the steering wheel was hard to turn compared to my Suburban. I attributed it to the short fat tires. Nope. It was the box being out of adjustment.
Correct it doesn't drive like a modern car. But it drives like a sweet old truck should now. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Grandpa: Yes, my truck steering is similar. It tracks well without a lot of minor steering adjustments. The times I notice a big difference from modern vehicles is on winding roads. The transition from straight to left or right hand sweeper is delayed and a bit unnerving at speed. This I attribute the technology of the day. Otherwise, the truck steers nicely for the most part. BTW, this truck is the only non BMW vehicle I own or have owned for many years. I mention this just as a point of reference to my comments on the truck steering. For a vintage truck, it good, but compared to my BMW's, not so good.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My 1 Ton probably steers a little better than when it was new because of the modern tubeless radials. I don't have any wander problems or shakes. What I have to get used to each spring is the long steering ratio. What would take less than a finger width of movement on a modern car translates into inches on the old design. | | |
