5 members (1955 1 Series, Charles in CA, Otto Skorzeny, Bill Trotter, dt235sd), 121 guests, and 5 robots.
Topics128,193
Posts1,057,367
Members48,469
Installing 4 speed transmission back on enclosed driveline splined shaft after the 3;55 conversion and noticed that the spline shaft extends 1 inch out of the encloser . Is that right? the yoke is about three inches long. Seems the spline is short. All help appreicated
52 suburban
48 Palace
This picture shows how far a torque tube propeller shaft extends past the torque tube housing.
This picture shows torque tube rear yoke bushing wear marks on the rear yoke.
When the rear yoke is slid onto the torque tube propeller shaft splines,
the wear mark farthest to the right is flush with the end of the torque tube housing .
The rear yoke normally rides about 2 1/2" onto/down the propeller shaft splines.
That is more spline overlap that is on the front yoke (upper left) bolted to the transmission main output shaft.
When the rear axle is not moving up or down, this Picture shows the position of the rear yoke on the propeller shaft splines.
This is the position of the rear yoke most of the time.
Depending on how much the axle moves up and down, will determine how much the yoke slides/rides on the propeller shaft splines.
This picture shows bushing wear marks when it gets hot.
Not only did you answer my question ,you educated me. thank you for taking the time to awnswer me.
52 suburban
48 Palace
