2 members (Ponchogl, Hush),
67
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 3 Junior Member | | Junior Member Joined: Oct 2002 Posts: 3 | WHEN INSTALLING THE FRONT FENDERS ON A 1951 IS IT NECESSARY TO PRE-INSTALL TO THE INNER FENDERS AND INSTALL BOTH TOGETHER AT THE SAME TIME? | | | | | | Anonymous Unregistered | | Anonymous Unregistered | | | | | | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | Ken, I agree with you. But I advise one word of caution (at least in my case) while your hanging the outer fenders leave the bolts loose before you install the grill ... it can be a b*tch. I put two pieces of heavy waxed paper between the grill and the fenders to help it slide into place. It helped a bit but it was still a tough thing to pull off. | | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Hey Skip, I just noticed your tagline there... Are you a "Knockabout Guy?!" Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
