| | | Forums66 Topics128,095 Posts1,056,067 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I want to install a Right Interior Sun Visor on my TF truck. Does anyone have the installation template for where to drill the holes, if so can you scan and email to me? I have the accessory installation book but that doesn't give measurements. Thanks, Mike B  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you can figure it with info in the acc install book, there should be a dimple in the header where the large hole goes, make a box board pattern from your visor base and center the large central hole over the dimple, mark and drill
Bill | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Bill, Got it...duh. If I drill the 1-1/2" hole at the dimple I can hold the hardware in place and line it up and mark the screw holes...sometimes I make things harder that they really are by over thinking, thanks for the help! Mike B  | | |
