1 members (keithfielder),
99
Mod | | | Forums66 Topics128,186 Posts1,057,318 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 24 New Guy | | New Guy Joined: Jun 2012 Posts: 24 | 1952 1/2 ton. V8 upgrade to a 350 but I want to retain 3 on the tree. I'm having a troubles. I found a '54 bell housing crossmember and bell housing from a 66 truck. I have a Saginaw full syncro 3 speed with overdrive. Mustang II front end. Power brake booster under the floor. I cut my steering column just below the shifter box on the column. Now the troubles begin. The shift linkage hits the valve covers. The brake pedal was hitting the exhaust manifold until I moved the engine forward a couple of inches. I'm waiting on a new radiator with electric fan, so I know how far forward I can mount the engine. Has anyone done all of this before. 3 steps forward and 2 steps back.....frustrating. thanks in advance....
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Chris, try asking in the HiPo shop, lots of modifications explained there. | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | The shifter arms for this application in Task Force trucks were bent backwards to clear the V-8.
| | | | | Joined: Jun 2012 Posts: 24 New Guy | | New Guy Joined: Jun 2012 Posts: 24 | Can I change shift rods from a newer truck? Or do I still need the intermediate shifting pivot that was originally on the bell housing? I would like to see the bent backwards photos.....thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | train, it's "arms", not "rods" - like on the 57-59 shift box in this pic - might help with clearance, as you can see on this 58Bill | | | | | Joined: Jun 2012 Posts: 24 New Guy | | New Guy Joined: Jun 2012 Posts: 24 | On the '52 it has an intermediate pivot point on the bell housing......can that pivot point be eliminated. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that will depend on if you have clearance to the toe/floor board and if you can find rods that will work from the shift box arms to the trans arms, but I didn't think the 66 had that intermediate point, it was an earlier thing
Bill | | | | | Joined: Jun 2012 Posts: 24 New Guy | | New Guy Joined: Jun 2012 Posts: 24 | the '66 didn't have that intermediate point. I will have to fabricate a pivot point that bolts on the bell housing. Or.........eliminate that factor and use a set of shift rods from a newer year and connect direct...... | | | | | Joined: Jan 2011 Posts: 212 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 212 | I bet the Shift Box Arm's Rubber Gromet did not like being roasted like that. Brass Bushing woiuld likely be the way to go there I would imagine.
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | I would forget about the pivot, that was a 6 cyl operation prior to 56. None of those parts are going to line up with the Saganaw side cover which has a complete different configuration. Locate a 2-3 shift rod from a TF truck as well as the shifter box mentioned previously. It will likely have to be bent to fit as well as the 1-R shift rod. It can be worked out, it will just require some "modifications". Fred
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Thriftmaster, the bronze bushings are the way to go anytime, on both ends of the linkage rods
Bill | | | | | Joined: Jun 2012 Posts: 24 New Guy | | New Guy Joined: Jun 2012 Posts: 24 | I'm figuring out that the first V8 in the '55 truck used the bent shift arm to clear the exhaust manifold. I will be happy to eliminate the intermediate pivot arm that was used on the 235. Where do I find brass linkage bushings?......sounds better that the rubber ones. Now I just need to find a '55-58 complete column. Not only for the newer shifter box, but also for the factory turn signal assembly. thanks for all of the suggestions....pictures say it all..
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | train, check the HELP! rack for #38374 hinge pin bushings
Bill | | | | | Joined: Jun 2012 Posts: 24 New Guy | | New Guy Joined: Jun 2012 Posts: 24 | HELP! rack at Autozone.....thanks Bill.....found them.
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | You cannot use a TF column in a AD truck. The column on both series is part of the steering box assy which are different. You can however, use the shifter box from a 55-59 V-8 truck and/or 56-59 6 cylinder. The turn signal housings used on TF trucks are the same as the units used on 53-54 cars. You may be able to adapt one to a AD column. Fred
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Fred, I was thinking the car signal unit might work, but I had to go back and look at the setup, he's already chopped the column at the shift box and has an M2 front  just the upper column from a TF should be OK, if a bit haywire  Bill | | | | | Joined: Jun 2012 Posts: 24 New Guy | | New Guy Joined: Jun 2012 Posts: 24 | I think a '56 column will work. Has the turn signals and the shift box with the lower bent shift arm. I will cut the column just below the shift box allowing room for a 'Column Saver' at the bottom of the housing. Then grind the shaft to a double 'D' and connect with 'U' joints to the rack and pinion. I may have to stay with the '56 steering wheel. I'll let you know how it turns out. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | train, '56 uses the same wheel as 54, so the splines will be the same, if the bottom of yours mates well with the signal cup, or not
Bill | | | | | Joined: Jun 2012 Posts: 24 New Guy | | New Guy Joined: Jun 2012 Posts: 24 | not panning out very well......can't find a 54-56 column with turn signals. I may have to settle for an aftermarket turn signal switch..... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | train, the 55-59 turn signal unit is reproduced, and the parts for it if you can find a used unit somewhere to go with a 55-59 column - and note that the 55.2 and 56 columns that used a 'flat' steering wheel are slightly longer than the 57-59s that used the deep dished wheel Bill | | | | | Joined: Jun 2012 Posts: 24 New Guy | | New Guy Joined: Jun 2012 Posts: 24 | I found the turn signal hub....seems to be the same as a 53 sedan. Thinking that the '52 wheel and a nice old aftermarket turn signal may be just fine. There are so many aftermarket turn signals. | | | | | Joined: Jun 2012 Posts: 24 New Guy | | New Guy Joined: Jun 2012 Posts: 24 | things are looking up.....found a '54 column with turn signals and wheel. It will work. | | |
