6 members (3B, Hanks custodian, Otto Skorzeny, Steveoreno, Cosmo, 1 invisible), 91 guests, and 3 robots.
Topics128,181
Posts1,057,174
Members48,465
I ratle caned a 59 cushman because i will eventuly replace the rear fiber glass tailcover.The scooter looks great for now.I sprayed the cover first with a close match that said adheres to fiberglass and then topcoated with a regular rustoleum gloss enamel.The paint on the metal wasnt bothered by a feul leak but the glaas paint lifted.any solutions? thanks ron
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
Could it be that the fuel attacked the fiberglass resin itself or the coat between the rustoleum and the fiberglass? A lot of rattle can paints aren't resistant to fuel.
Paint & Body Shop moderator
is a clear coat feul resistant?Ron.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
Did you put the paint on the actual fiberglass or the gelcoat?
There's not much that will adhere to gelcoats, epoxy primer is about the only product I would trust, this may be your problem, it looked good but the fuel found it's way between them!
