| | | Forums66 Topics128,180 Posts1,057,158 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | I ratle caned a 59 cushman because i will eventuly replace the rear fiber glass tailcover.The scooter looks great for now.I sprayed the cover first with a close match that said adheres to fiberglass and then topcoated with a regular rustoleum gloss enamel.The paint on the metal wasnt bothered by a feul leak but the glaas paint lifted.any solutions? thanks ron .
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Could it be that the fuel attacked the fiberglass resin itself or the coat between the rustoleum and the fiberglass? A lot of rattle can paints aren't resistant to fuel.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | is a clear coat feul resistant?Ron.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Nov 2004 Posts: 61 Member | | Member Joined: Nov 2004 Posts: 61 | Did you put the paint on the actual fiberglass or the gelcoat?
There's not much that will adhere to gelcoats, epoxy primer is about the only product I would trust, this may be your problem, it looked good but the fuel found it's way between them! | | |
