1 members (delky), 127 guests, and 3 robots.
Topics128,193
Posts1,057,258
Members48,466
Need help again.
I am in progress of dismanling my engine, 235
how do seperate the pully from the crank shaft.
I cant find lock screws or nuts.
Thanks for your help
:confused:
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
Do a search for the thread on this topic. It has been covered quite well. You will need a puller that uses bolts that thread into the pully.
1951 1 Ton Completed
There should be two threaded holes in the harmonic balancer. You will need a balancer puller which works like a gear puller. You should be able to rent or borrow one from your parts store. [img]http://www.harborfreight.com/cpi/photos/37700-37799/37714.gif[/img]
Also, while you have the crankshaft out, get the end drilled and threaded for a retaining bolt. This will help a lot when putting the balancer back on and will allow you to use a bolt to make sure it stays in place.
Fred
52 3600
69 C-10
