1 members (baldeagle),
37
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 15 New Guy | | New Guy Joined: Aug 2014 Posts: 15 | Wanting to order some engine parts today and not sure what I have. 1950 11/2 ton it is origenal motor. I have heard 235 or maybe 260something. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Your best bet is to get the numbers off the pad on the engine block that is next to the distributor. Your truck could either have a 216 or 235. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In 1950, it would have been a 216 or, more likely, a 235 (if you still have the original engine).
Find and post here the Engine Serial Number that is pressed into the block just to the rear of where the distributor goes into the block.
| | | | | Joined: Dec 2002 Posts: 2,548 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,548 | 235 was standard in all 6000 series 2 ton 16000lb. gvw trucks, but yours being a special order 15000lb. 1 1/2 ton 6400, it could possibly have a 216 in it. best to get the engine casting number on the passenger side of the block, plus the eng. id number from the flat ledge, at the base of the dist. shaft, where it goes into the block. | | |
