1 members (216wny),
158
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,874 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | anyone know if napa ,oreillys would have front brake hoses that i could make work on 1958 3/4ton ?? or where i can get the proper ones. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I had to have a hydraulic hose place make some for a '59 1-ton several years ago. Nobody stocked them then. You might try Rock Auto. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy rwb, for some reason my catalogs have an N/A when it comes to 1958 3/4 ton front hoses, a little detective work yields three possibilities, at RockAuto Wagner p/n F23933 which is 18 5/8" overall length $20.79 Raybestos p/n BH4900 which is 17 11/16" overall length $10.29 at Napa p/n UP25664 which is 20" overall length $27.49 p/n UP4900 which is 17 11/16" overall length $11.49 hope that helps. | | | | | Joined: Jun 2012 Posts: 1,748 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,748 | We have a local "House of Hose" That can make up any hydraulic hose you need. Any fitting at any length.
Northern House of Hose 800 30th Avenue # B Fairbanks, AK 99701 - View Map Phone: (907) 451-5534
I don't know how close these folks are to Homer but they might be able to help.
Steve H
| | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | thanks all got the hoses local napa left the hose with one of the friendly counter persons and they did some extra research and found them. now to the rear drums!! (next post)
