6 members (GMCJammer51, Greg_H, NorCal52Suburban, Hush, Cosmo, 1 invisible), 70 guests, and 2 robots.
Topics128,073
Posts1,055,908
Members48,429
Hello,
Just wondering if anyone is running one of those quick efi setups on their ad? I have a '54 chev stake truck (2 ton) with a full pressure 235. The motor runs strong and have recently converted it over to 12 volts. Other then that all original. Thinking about running a Clifford 4 barrel intake and maybe the Holley quick efi setup with Fenton headers and a larger cam. Just wondering if anyone has any experience with this or if there's a better way to go?
Thank you very much!
1954 Chevy 2 ton stake
Full pressure 235
12 volt
4 speed manual
1. They are expensive.
2. Talk around the local shop says they work pretty nice (SV8 experience).
Yeah I definitely see the expense part. I was debating if that's worth it for a long term thing. So basically if I buy a 4 barrel intake and run a small 4 bbl carb then down the road go quick efi or if I'm better off just getting a 2x1 intake and running that for a long time. Trying to not see what's a smarter purchase for the long run.
Thanks for the response
Full pressure 235
12 volt
4 speed manual
