2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#1052331 08/27/2014 9:32 PM
hi guys ,need help again.i am trying to puut a 327 in my 55 panel. I want to used the rear mounts on the bellhouseing and the two mounts on the front.could someone show me a picture of how it was used in a55 pickup?,,,,thanks
johnhull #1052357 08/27/2014 11:50 PM
assume you've decided to go with a manual trans so a trans crossmember isn't necessary? setup was the same for all size pickups or panel - will be some pictures in the manual of different areas - here's an overview, if you don't have the parts necessary to set the rad back like factory, you'll need a shroud [all the vendors have them] - here's where the front mounts go, need that add on frame bracket, but the whole front mount setup is also available from vendors - this shows position and why they changed to that bent shift arm
