| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | hi guys ,need help again.i am trying to puut a 327 in my 55 panel. I want to used the rear mounts on the bellhouseing and the two mounts on the front.could someone show me a picture of how it was used in a55 pickup?,,,,thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | assume you've decided to go with a manual trans so a trans crossmember isn't necessary? setup was the same for all size pickups or panel - will be some pictures in the manual of different areas - here's an overview, if you don't have the parts necessary to set the rad back like factory, you'll need a shroud [all the vendors have them] - here's where the front mounts go, need that add on frame bracket, but the whole front mount setup is also available from vendors - this shows position and why they changed to that bent shift arm Bill | | |
