Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Ponchogl), 108 guests, and 2 robots.
Topics128,281
Posts1,058,466
Members48,490
#1052191 08/27/2014 3:09 AM
I have a 54 3100 with the 3 speed. Just acquired a 51 4 speed and would like to swap it in for the floor shift. Are the clutch parts the same or will I have to change the clutch also? As far as I can see they are both 10" discs, same splines etc.
You could use the 54 3!00 flywheel and clutch assembly with the 51 4-speed. You would use the 54 clutch housing.
For reference here is an original 1954 Chevrolet 3100 Truck with 4 speed Photo Album.
