1 members (Hotrod Lincoln),
136
Mod | | | Forums66 Topics128,281 Posts1,058,465 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | I have a 54 3100 with the 3 speed. Just acquired a 51 4 speed and would like to swap it in for the floor shift. Are the clutch parts the same or will I have to change the clutch also? As far as I can see they are both 10" discs, same splines etc.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | You could use the 54 3!00 flywheel and clutch assembly with the 51 4-speed. You would use the 54 clutch housing.
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | For reference here is an original 1954 Chevrolet 3100 Truck with 4 speed Photo Album. | | |
