6 members (SmalltownTRKGuy, Gdads51, Lightholder's Dad, GrandpasJimmy, Jon G, Otto Skorzeny), 97 guests, and 2 robots.
Topics128,194
Posts1,057,248
Members48,466
can anybody tell me if install this rear under my truck does it have the same lug pattern as an s-10 rear or do I have to get different wheels for the back?
The bolt pattern is different than a S-10
8.8 Ford rear is 5 x 4.5" 1/2" fine thread
You could have the axles re-drilled for other patterns. Strange, Currie, those kind of folks will do that.
Many aftermarket wheels come with both Chevy and Ford patterns, so if you have not bought wheels, that is the easiest option.
I don't know what S-10 pattern is, but if it is typical Chevy they are 5 x 4.75" and the lugs are 7/16" fine thread.
Jeeps use the same lug pattern as the 8.8. Everything you probably want to know about the 8.8 at ww.therangerstation.com/tech_library/Explorer8_8.shtml
Other than the name and the lug pattern, the 8.8 with 31 spline axle from the Explorer is a nice cheap rear to consider for modernizing old Chevy trucks. Disc brakes, limited slip, friendly ratio of 3.73, and 3200 lb weight rating.
R-Bo
1966 GMC 305V6 in the family
DAM, guess I gotta stick with a chevy rear.....im running corvette rally wheels on my truck, and dont wanna change them
S10s are 5 x 4.75 with 12mm x 1.50 studs. If you want the real hot setup using an S10 rear, find one from a '98-'04 with the ZR2 off road package. It will have what amounts to a narrowed version of the 8.5" rear found in the '88-'98 full size 1/2 ton trucks, including most of the Z71 off road package trucks and SS454. They are wider than the standard 4x4 S10 by about 2", and have a very good rear disk brake setup.
Bill Burmeister
