| | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2014 Posts: 35 | Is there a known and.accepted "From the factory" color for Jimmies?
See alotta trux with battleship grey, but I heard GMC's had a blue motor? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | From the oldGMCtrucks.com discussion board: SlmSix (Andy from MN): So with the help of K10 I have come up with what I believe to be the correct "olive" green paint color for the 1939-1950 GMC 6 cylinder engines. Pete was kind enough to send me a flywheel cover off his original 228 that used to live in his '45 pickup. He replaced the original 1945 228 at one point with another 228 and painted the replacement engine using green paint that was computer matched off of the 1945 228. The paint he used was a Centari brand put into rattle cans which is no longer readily available. The local store for me uses PPG products and they can put acrylic enamel in spray cans. So I went and asked them if they could cross the Centari formula to a PPG equivalent. No go. However, looking through the PPG Fleet color chip books they had on the counter, I found a nice selection of olive green paints. I compared them to Pete's flywheel cover and got lucky! The PPG 45244 Beechcraft Olive Green was just about perfect! | | | | | Joined: May 2004 Posts: 11 New Guy | | New Guy Joined: May 2004 Posts: 11 | | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | In 1950 the engine for GMC was the red/orange not olive green. If you will search, I think you will find plenty of discussion on it.
