1 members (Danielbolt), 164 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,456
I'm restoring the above truck and am trying to figure out what to do about the suspension. The truck is completely original as far as I can tell. I have two questions:
How many leaves should the springs have front and back?
How would you tell if your springs are worn out?
I'm new here and I have been amazed at the wealth of knowledge and the spirit of helpfulness shown by the members. Thank you for your help.
I don't know about the spring count, but to determine if your springs need to be replaced you first do a visual inspection and look for broken leafs. Next would be to check the ride height and compare it to factory specs.
