8 members (3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, Joe H, Joe Lowe III, 1 invisible),
77
Mod | | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Am I correct that the rear tail Light on my 1951 chevy suburban barn door was the same from 1947-1956 ?Steele rubber advertises the tail light gasket for 1947-1950. I emailed them and told them the same tail light was used up to 1956. This is the response I received.
We received your request concerning the T/L / Brakelight gasket that we offer for the 1950 Chevrolet Suburb. Our research has not come up with anything as far as that fitting through 1956. I might suggest you can purchase this part and you may return for a refund if this doesn't work. Please let me know.Thank you,Terri Caldwell Product Specialist Steele Rubber ProductsAm I correct or not ?Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's still the same light to 56, and other suppliers list the seal for 47-56, but Steele is pretty picky about having factory documentation /good originals to copy, so it might just be lack of documentation for them, very fair offer to refund if it doesn't work - but it will Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I bet the reason that Steele does not think they are the same is because the Master Parts Catalog has to list them as different assemblies. All the parts in the assemblies are the same, except for the 12v bulb from 1955-2nd series onwards. So, the almost-identical 1955-2nd onwards 12v assembly has a different part number.
Added later - I think I am wrong on this. It looks like the assembly changed in 1955-2nd. The assembly should be the same for 47-55st
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I wonder why they don't show it 1947-1954 then ? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The only 47-55st difference that I can think of is how the connection/lead is made from the cab-body to the rear doors.
That should not affect the gasket/seal.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Right,1952 and up used the wire loom instead of the contact switch to activate the light. The light housing and gasket are the same.
you would think they'd know that.
Tim
