| | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 85 Shop Shark | | Shop Shark Joined: May 2005 Posts: 85 | Hi,
Installing a one wire alternator on my 56 Chevy pickup and need a little help. Someone (OK, It was me ) disconnected the wires from the ammeter and now I don't know the pin outs on the back of the gauge. Which side is positive? My understanding is that I connect the alternator to the positive side of the ammeter and the negative side of the ammeter to the starter. Sound right? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | got a wiring diagram? across that diagram there's a line that's labeled "front of dash", beyond it the headlights, that diagram is laid out exactly like the truck, facing the dash you can see which wire goes where .... easy Bill | | | | | Joined: May 2005 Posts: 85 Shop Shark | | Shop Shark Joined: May 2005 Posts: 85 | Hey Bill,
Funny, I have looked at that wiring diagram so many times and never noticed the front of dash line. Only two connectors on the ammeter right?
Thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes 2, although sometimes folks use the ammeter to tap off for accessories, as it's a battery connection
Bill | | | | | Joined: Dec 2013 Posts: 789 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 789 | I have a 1947 3100 with a 12 volt electrical system. Recently, I put new brushes and a voltage regulator in the alternator. However, I have to 'excite' the alternator on every restart in order to get it to put out 13 plus volts. The alternator has a battery wire and a two-terminal connector that has a jumper wire from the battery terminal to terminal number 2.
Any ideas how to remedy this condition? By the way, the PO has a simple toggle switch for the lights. Do I need to install the original light switch to resolve the issue or is there another problem with the alternator?
Thanks for your help!
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | I have a two pin alt on my 52 1/2 ton. I also have a 12 volt regulator. No one wire here. It takes a single rev up to about 1000 rpm to get it charging. Works fine and has no issues. I hit that rpm range at the first shift point from my driveway and after that no problems. I only use one pin out of the two, battery. It might be an internal regulator? It might not. It works so I have not messed with it. Will yours self excite at higher RPM? If not you might have a defective BOOB(Bad Out Of Box) regulator. Load switch like your headlight switch won't have any effect on the alternator, But might cause some issues if not fused.
Steve H
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | is there another problem with the alternator? You have gotten one of the early style internal regulators that don't self-excite unless the idiot light circuit is connected. You can either install a 2-wire warning light from the ignition switch output through the bulb to the unused blade terminal on the regulator, or swap to a later-design regulator that has an internal excitation circuit. The newer regulators (sometimes called "1-wire") work as soon as the alternator RPM is goosed up a little after startup. Jerry
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Now, that I did not know. Thanks Hotrod!
Steve H
| | | | | Joined: Dec 2013 Posts: 789 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 789 | Thanks Hotrod and Steve,
I apologize for my late reply, a family member is hospitalized. All is well, so it's back to my p/u!
Thanks again,
