Originally posted by likearock:
[QB
What is the best way to fill the holes where the clips were?[/QB]
Plug weld them!
Body filler won't hold up and unless you can seal the the backside it will rust through.
When plug weld,use a brass backing until you fill the hole,then remove.
Aluminum backing works also.
What are you going to do with the old trim? Looks like it's in fair shape.
