0 members (),
148
0
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 51 | Starting to look around for a Taskforce truck again, and starting to look around here, so will be looking for a Canadian '55-'56, but try as I might, I'm not lucking out at finding a page or website dedicated to Canadian made '55 - '59 truck specs. I could swear there use to be such info, but just can't seem to be able to find it again. Can anyone help? Just want to do some reading/learning, so that when looking at a truck, I can see what is correct, and what might be wrong with it. Thanks in advance!  | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Before My time, I am not aware of the website you mentioned. Once you have a likely candidate you could post the serial here and your fellow Canadians can help you decipher it. | | | | | Joined: Jun 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 51 | Thanks 3B!  I do have a grasp on how to read the vin numbers...what I thought I had found a while back, and what I was looking for again lately, were specs and options info...I6 or V8...color...pics...etc  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the Canadian & US versions of the TF trucks are really the same specs, except for the ID codes and tags and the fender series emblems .... for the US TF trucks, Mike B has a page here with some ID details, and there's a short run down here of years, and there's lots of info at the Old Chevy Manual site .... for CDN specific info, the only place I've ever seen is this pre-55 site, although they do have the CDN vin decode info for 55-57, which came from an old Scotts Super Trucks paper catalog .... good luck with the hunt! Bill | | | | | Joined: Jun 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 51 | Thanks 52_Ton, and red58!!  I know there are other differences, like didn't the Oshawa trucks come stock with 16" rims, while they only got 15" rims down south? Is that correct?? ...wish there was a Canadian Taskforce site... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 15's were the standard wheels either place ... the 57 CDN glovebox book I have lists 15 as standard, 17.5 and 19.5 optional for the 1300 and 1400 series, I'd expect that was the same for 55-6, might not have been an option for 16's in Canada .... you'll have to start collecting the info and put up a CDN site  I should add the standard engine in Canada was the 235 with the 283 V8 as an option, and AFAIK the color offerings were the same as in the US Bill
| | | | | Joined: Jun 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 51 | Very interesting...see, I did not know that. I'm guessing the 283 option would show up on the vin on the Canadian truck...correct? So if I were to see a truck with a 283, it should have an 8 instead of a 6 in the vin, or a v? Oh, and I might just to that...the Canadian site thing, but I'll need a lot of help to get it done right!! It should be more of a collaboration project  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | after the model/series numbers in the vin, is either '6' or '8' to indicate engine .... I'm sure folks here who have CDN info would collaborate - but as I said, there really isn't much difference in the trucks - here's the US options list, and no doubt a purchaser could have ordered about anything added just like in the US, including a range of 3rd party goodies available via the dealer Bill | | | | | Joined: Jun 2013 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 51 | Hey Bill, Thanks!! So if the vin says it's a 6, and I find an 8 under its hood, then that means the engine was changed...fair enough. I figured there would have been a few differences that would make a Canadian truck stand out, (even if just a different paint scheme...oh, now I have to find the paint/colors chart available back in '56) but if they are basically the same as the US trucks, then I'll just those as guidance when looking for my own  Thanks again!!
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | another way to tell if the V8 is a change is the front mounts were riveted on at the factory, bolted on if done later, and really fake would be add-on side engine mounts - and of course, a 55/56 should have a 265 if still an 'unmolested' original the Factory Assembly Manual is a pretty good guide for the 55/56, it even includes the right hand drive details, which were primarily assembled in Canada for export, the differences not shown are the series designations, particularly for the emblems .... 56 paint chipsBill
