0 members (), 67 guests, and 3 robots.
Topics128,055
Posts1,055,782
#1041323 07/10/2014 1:35 AM
The clips that go between the moulding and the rubber seal,10 correct?, two on the upper and three on the lower, each side, but there do they go? Looked in FAM they showed a picture of the clips, but did not show there they go. I think they go next to the screw holes in the moulding, correct. I also found small rubber pieces next to the defrost outlets. Are they there to keep the air flow going up and not out into the moulding? 53 3100 Root
I found out about the clips and rubber seals from another forum. The clips go between the screw holes to keep the vibration down and the rubber goes at each end of the defrost vents. root
Thanks! I'll need this info in a couple months!
gentlemen thxs for the info.
52 suburban
48 Palace
Moderated by  ndkid275, Phak1
