| | | Forums66 Topics128,187 Posts1,057,315 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 71 Shop Shark | | Shop Shark Joined: May 2001 Posts: 71 | I've set up my bed and running boards, everything is in the correct location but one of my rear fenders is a little over 1" short of reaching the running board. I can bolt it together and it looks fine, but that's putting some pressure on the fender. Is that pressure okay, or should I attempt to do something with the fender? I'm concerned about pulling it together and flexing it after paint. It does look like the fender shape is fine though.
'53 Chevy truck 1/2 ton
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Are you sure your bed is not racked? Or that the fender isn't bent at the front? I wouldn't want to put that much stress on the toe of the fender for fear of developing cracks down the road. They usually develop cracks there anyway even when it was a factory fit.
DG
Denny G Sandwich, IL
| | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | Check to see if your bed is square by measuring diagonally across the front and rear bed corners. The measurements should be the same. Don't ask me what to do to bring it back to square. You can figure that out and come back and tell me something new.  Carl
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | There is "slop" in the fender mounting holes. Try loosening the fender for easier alignment.
Drew
