8 members (Chip O, MNSmith, Woodcmiami, LAROKE, Hotrod Lincoln, Southerntruck, gswbbc, 1 invisible),
113
Mod | | | Forums66 Topics128,032 Posts1,055,523 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | Whats the best way to clear my oil lines since the block is pretty much clear? My crankshaft is still in, so if I used compressed air won't I be trapping all the oil gunk there? Everything else is out..pistons, head, etc. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | take the crankshaft out, and take out the oil gallery plugs. Use long rifle type brushes (harbor freight has a good assortment) in a drill, and solvent. You can't get it too clean. However I don't really know what you are trying to accomplish, taking it that far down and not going the rest of the way doesn't make a lot of sense to me. | | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | ok. thanks.
all that i need to do to take out the crankshaft is unbolt those bolts holding it down, correct?
Does the timing gear come out with it? Is there anything special to putting the crankshaft back in?
I was originally working on compression issues, which lead to pulling pistons to redo rings. That is how I got to this point,but since Im here it seems to make sense to clear out oil lines... | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Yes. Mark the main bearing caps if you need to. Pull the bolts and if there are shims, make certain they go back in the same places they came from. You got this far the rest is straight forward. Good time to replace the rear main seal and measure the main bearings and crank. Putting it back in requires some muscle and a soft touch. But you can do it. Crank is heavy so get help if needed.
Steve H
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | When you put the crank back in make sure the timing marks are aligned properly.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Feb 2004 Posts: 29,758 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,758 | Doesn't the front plate under the timing gears have to be removed before the crank will come out? Jerry
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | As usual Jerry is correct. The front plate will have to come off. As well as the timing gear.
Steve H
| | | | | Joined: Jul 2013 Posts: 109 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 109 | | | |
