7 members (Donf, Hanks custodian, Cosmo, Gray_Ghost, treegrower, Bill Hanlon, 1 invisible), 105 guests, and 1 robot.
Topics128,080
Posts1,055,956
Members48,430
#104998 03/11/2002 12:57 AM
I'm getting a Sear Pro MIG welder for my Bday. It comes with a gas regulator, but no gas bottle. So, um, where do you get the bottle? And what kind of place do I look for in the yellow pages to fill it? :confused:
My first project will be to fill in the shift bar on my 41 Chevy car. PO ground it down wrong (where bolt goes through attachment at bottom end) so reverse sticks way up and first is level. (Even with housing rotated max. Its got a 49 linkage.) :mad:
For a fill weld, do I need gas? Can I use flux cored wire? :rolleyes:
Thanks!
Jim
#104999 03/11/2002 1:37 AM
Go right to gas sheilding welds. Flux core is for high wind conditions only and is junk when it comes to autobody work. Find a welding suppy store to get the bottle and go with a 75-25 Argon, Co2 ,mixture.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#105000 03/11/2002 4:07 AM
Anonymous
Unregistered
Anonymous
Unregistered
Get a 165 cu-ft bottle 75/25 like Mrtnsr says. Get .035 wire or perhaps smaller if you aren't doing anything thicker than 1/4 inch. I ferget how much I paid for my bottle, but I bought it rather than renting . . . not knowing how often I will have to fill it up I figured buying was better.
HAVE FUN WITH IT!!! smile
#105001 03/11/2002 9:25 AM
Go to welder's gas supply house, check phone book. Even if you "buy" the tank for around $75 or so, it will not be a new one and you just trade it in when empty and only pay for the gas that way. Some farm stores have new tanks, you have to go fill them still, or trade that nice new one in on a beat-up returnable like above. The mix of 75-25 is the best. Think with gas you only use .023 wire, check your manual. .035 is usually the core size wire. Don't forget to change your wire drive rollers to right size wire. Gas sheild makes better/cleaner welds. You still have to knock slag off the core wire welds, just not very much of it is all.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#105002 03/12/2002 4:16 PM
I got mine from Praxair. See if you have a local Distributor.
http://www.vicinity.com/praxair/startprx.hm
Kelly
1951 Chevy 3100
1967 RS/SS Camaro
#105003 03/13/2002 4:48 AM
Also remember to reverse your polarity on the welder when switching from fluxcore to gas shielded welding. I use a 20 pound bottle, lasts about l year or about 2/3 of a ten pound spool of 023 wire. I've always used straight CO2 for welding, may try the mix one of these times just to see difference in welds. smile
