3 members (Hotrod Lincoln, Chip O, Steelonsteel), 125 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
http://i.imgur.com/qavLMyZl.jpg
The seller said I could have it for $100, shipped, so I got it. It's from CPP, has the bracket to mount to stock bracket, 8" booster, but how do I identify what kind of prop valve is on this? It's not marked in any way and if it's not for disc/disc I need to buy one that is.
Have you thought about asking PPC your question?
Classic Performance Products 378 E Orangethorpe Ave., Placentia CA 92870 Tech Line 714-522-2000
Harold
Harold
Yep, but they're phones were too busy today so I thought I'd post here after I thought of that first.
I would order one of these.
http://www.speedwaymotors.com/Wilwood-260-11179-Adjustable-Proportioning-Block,41747.html
You will be able to fine tune your brake bias and the end result will be worth the few $$$.
Go to the CPP website and look in the Tech tips area. I believe there is an article on removing something from the valve so it can be used with 4 wheel discs.
If it turns out it's for disc/drum and you can't use it, I'd be interested in it smile
1952 Chevy 3100
Semper Fi !
