| | | Forums66 Topics128,196 Posts1,057,390 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | http://i.imgur.com/qavLMyZl.jpgThe seller said I could have it for $100, shipped, so I got it. It's from CPP, has the bracket to mount to stock bracket, 8" booster, but how do I identify what kind of prop valve is on this? It's not marked in any way and if it's not for disc/disc I need to buy one that is. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Have you thought about asking PPC your question? Classic Performance Products 378 E Orangethorpe Ave., Placentia CA 92870 Tech Line 714-522-2000 Harold
Harold Is a restoration ever finished? | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Yep, but they're phones were too busy today so I thought I'd post here after I thought of that first.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I would order one of these.
http://www.speedwaymotors.com/Wilwood-260-11179-Adjustable-Proportioning-Block,41747.html
You will be able to fine tune your brake bias and the end result will be worth the few $$$. | | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | Go to the CPP website and look in the Tech tips area. I believe there is an article on removing something from the valve so it can be used with 4 wheel discs. | | | | | Joined: Oct 2013 Posts: 98 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 98 | If it turns out it's for disc/drum and you can't use it, I'd be interested in it
1952 Chevy 3100 Semper Fi !
