2 members (Dennys28, 1 invisible), 93 guests, and 3 robots.
Topics128,059
Posts1,055,818
I recently purchased a set of leaf springs off of a 1954 GMC 1/2 ton to put on my 1954 Chevy 3100. I fugured they would be compatible. The front springs worked okay and bolted right up, but the rear springs turns out the alignment bolt in the middle of the spring is nearly 2 inches closer to the shackle bushing then the spring I removed from the truck.
Are the rear springs from a 54 GMC different than those on their Chevrolet counterpart?
One thing I found attractive about the springs is that they're 10 leaf.
<recently added>
The photo below show the alignment pin location on the spring that came off the truck and the one I was seeking to put on the truck -- painted grey.
Photo 1
Photo 2
</recently added>
Any comments would be greatly appreciated.
Walt Williams
La Verkin, UT
Were both equipped with torque tube rear end? Any chance one of them was a 55 1st series?
According to my Hollander's Manual, the same springs were used for '47-'54 GMC and Chevy half tons.
Do you have an open driveline rear end? Early model '55s had the same cab as '54 and open driveline. The hole in those springs is near center of the springs. You could have a '55 first series originally bought in and titled as a '54.
Excellent point. I didn't think of that. The person I bought this from stated that his GMC pickup was a 54. It may in fact it may have been a 55 1st series. I know the 55 1st had an open drive shaft.
My truck is a 54 with enclosed drive shaft.
Photo 1
Photo 2
Walt
I have now asked that question of the person that had the truck.
Walt
If the hole is centered between the eyes it most likely is for a '55 first.
The alignment pin IS centered between the bushing eyes, so it looks like I have a pair of 1955 1st rear, 10 leaf, leaf springs.
Walt
