3 members (JW51, mo2cyl, 1 invisible),
223
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 36 Junior Member | | Junior Member Joined: Jan 2003 Posts: 36 | Is the 1954 Chevy tailgate interchangeable with earlier or later model tailgates like the 50-53 Chevy Models or 55 Chevy 1st or 2nd Series?? Thanks for your help Robert | | | | | Joined: Nov 2001 Posts: 122 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 122 | The tailgate prior to '54 (AKA '47 - '53) won't fit a '54 that is the year they changed from the angled bed sides to the flat bed sides. from '54 on up into at least the mid '60's, (I'm sure someone will chime in with the correct year), the tailgates for the stepside beds were all the same. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | It is even better than that. The stepside tailgate is the same from 1954 through 1987. One can be bought at your local GM dealership. Though not cheap.
Mechainiac, your auction doesn't mention the year of your gate.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I did not know for sure how far it went up to . That is good to know the lettering design (script) is different through the yaers though. Someone should post a better pic of that tailgate if they wanted to sell it. :rolleyes:
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Gee, I thought that tailgate was green the first time I looked.
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Looks like it is trying to be made green,,,,,a little-bit anyway
