1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 122 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 122 | Is it possible to replace the fuel gauge without removing the cluster from the dash? Or, is it necessary to remove the cluster and take off the glass. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | If it is a 55-59 chevy you need to remove the cluster. Three screws and a speedometer cable. | | | | | Joined: Oct 2013 Posts: 122 'Bolter | | 'Bolter Joined: Oct 2013 Posts: 122 | Sorry . . . 53 3100 1/2 ton truck. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | You have to pull it out of the dash in order to get the glass and bezel off to change it. Just did one in a 50 Chevy truck.
