7 members (GMCJammer51, D B Cooper, treegrower, 2-Ton, 55shaker, Phak1, 1 invisible),
132
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,072 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | anyone using molasses to remove rust ??? i am having trouble finding sulfured molasses. which you are supposed to use. the feed store in anchorage has the molasses and the sulfer seperate. can i add the sulfer myself ??at what ratio ?? to make sulfered molasses. | | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | I just bought a bag of molasses flakes from the county feed store, it was like $17 for a big old bag. Worked fine. I guess it was a 50 pound sack or so, and I just topped up the rubbermaid garbage can w/water. In fact you just reminded me I forgot and left something in it for about 8-9 months now I'll have to get that out this weekend. | | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | is the bag stuff sulphated ?? i can 50 lb bag for 42.00 or 5 gal for 50.00. but not sulphated i was wondering if can buy the sulphate and add they have it 33.00 50 lb thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | way cheaper, as well as much less smelly and messy to use electrolysis - only thing you need to buy is some inexpensive washing soda at a supermarket
Bill | | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | thanks red58 talked me into it i think i will go ahead and do the electrolysis method. been reading up online about it. i have a gas tank i will try first.been empty for years. rusty inside.i am sure i can find some more rusty parts! .
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there's also a write up in our tech tips if you haven't seen that - other than mechanical means [grinding/sanding] I use electrolysis exclusively, works great
Bill | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | I used the electrolyis for a 16in wheel. Worked fantastically! Definitely plan to use that method for a few more things (headlight buckets are next to go in) | | |
