1 members (ShopRag), 170 guests, and 3 robots.
Topics128,271
Posts1,058,314
Members48,485
#1049225 08/13/2014 6:22 PM
I have a 1948 chev panel truck and have put in a gear vendor overdrive. it work great but I think that the 456 rear end is being pushed to hard and thought that I could drop in a 411 ring and pinion. Will that help or not. I believe that it is a 456 and without taking the back off the rear end can I turn the drive shaft and mark the wheel to know what I have for sure and if so how.
Thanks for your help
first48 #1049244 08/13/2014 8:49 PM
3/4 tons were usually either 4.57 or 5.14 to one. Why do you think it is running to hard??
first48 #1049290 08/14/2014 1:26 AM
Originally Posted by first48
can I turn the drive shaft and mark the wheel to know what (gear ratio) I have for sure and if so how?
Follow this procedure:
To check rear end ratio jack up one tire if you have an open diff, or both tires if you have a working posi or locking differential. With the tranny in neutral (block the front tires first) rotate the jacked up tire one full revolution for posi's and lockers and 2 full revolutions for open diffs. Carefully count the number of full revolutions the driveshaft makes. This is your gear ratio. In other words, if the drive shaft turns 3 ¾ turns, you have a 3.73 gear ratio. Turning the tire for twice the number of full revolutions and dividing the drive shaft revolutions by two will give you a more accurate reading.
Hope that helps! thumbs_up
