4 members (Southerntruck, Samantha, TUTS 59, tclederman), 106 guests, and 3 robots.
Topics128,036
Posts1,055,458
Members48,422
#104929 04/03/2004 9:29 PM
I'm trying to align my frontend prior to painting to make sure it all fits. There is a pretty large gap on the driver's side between the hood and the fender right in front of where the cab ends. It's almost large enough where I can stick my pinky through, then the gap gets good towards the front of the hood. The passenger's side is good. I can't make the hood go down any further and the fender won't go up any more in the rear. Anyone have any tips?
'53 Chevy truck 1/2 ton
Have you tried loosening the back hinge where it attaches to the cab and move it down? Don't forget the hinge to cab bolt on the inside of the cab.
Have you tried removing the hood tension spring and seeing if that helps with the gap. You might just need to lower that spring as well.
Joe
