7 members (Guitplayer, JW51, mo2cyl, Otto Skorzeny, 55shaker, Wally / Montana, 1 invisible),
73
Mod | | | Forums66 Topics128,050 Posts1,055,757 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | How long should the choke be pulled out on a well tuned carburetor? I recently rebuilt my YF 2100S and also re-jetted the metering jet. It runs great and only needs the choke to be used for about 20 seconds just to start it up from a cold start. It doesn't seem like it's running rich. I've got the mixture screw turned out 1.5 turns. Just wondering what the consensus is on a well tuned carb and a manual choke.
Mark | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | What is the air temperature? It may be you only need it for a cold start. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | The less choke you use the better it is. Sounds like you're doing it right.
I run a Rochester B which has a step cam on the choke linkage that slightly opens the throttle plate with full to partial choke applied which slightly raises the idle rpm while it warms up. I used this feature at 1st but soon found out I only need partial choke to warm up in winter and none during the warmer months.
If you really want to fine tune your idle mixture, get a vacuum gauge, connect it to the vacuum port on the manifold then set your idle speed to between 450-500 rpm then adjust the idle mixture in/out to get the highest and steadiest vacuum reading. A reading from 16 to 21 is acceptable. Good luck Dave | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | My 235 with a Rochester B will need the choke on the fist start of the day..why? I don't know. After that is good to go. Summer time it is on for about 15-20 seconds. Then off you go. Last winter it took a few blocks pushing it off a bit at a time until it was all the way off. Well tuned? It starts easy, runs well and gets me there. Gas milage? Maybe 15 in town, and a bit more on the road. Works for me.
Steve H
| | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I'm getting a reading between 19 and 20 on my vacuum gauge. We're about 20 ft. above sea level. I'm hoping that I did everything right on this rebuild. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | All motors require choke use in every climate, for every cold start, "cold" being 12 hours off. If it needs none or less, it's too rich and you're dirtying your plugs, adding gas to your oil, and killing your mileage. | | | | | Joined: Nov 2002 Posts: 2,765 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,765 | How long should the choke be pulled out on a well tuned carburetor? I recently rebuilt my YF 2100S and also re-jetted the metering jet. It runs great and only needs the choke to be used for about 20 seconds just to start it up from a cold start. It doesn't seem like it's running rich. I've got the mixture screw turned out 1.5 turns. Just wondering what the consensus is on a well tuned carb and a manual choke.
Mark Mark - I personally have converted ALL of my older vehicles to manual choke except for one numbers matching show vehicle that I no longer own (no fun after it was done). How long the choke should be engaged depends on the ambient temperature, city or highway driving, and the type of transmission (auto transmissions REQUIRE longer choke times). Take a look at the post by Panic right above mine. He is absolutely correct. MOST calibrate their carburetors TOO RICH for a variety of reasons. Lots of fuel wasted because of this. My current shop truck from the 1960's with a large 450 HP V-8 with dual 4-barrels obtains about 22 MPG at 70 MPH. And yes, I have manual chokes on both! It IS possible. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I do prefer the manual choke on these older carbs. Jon - That makes sense your reference to temperature. It doesn't get very cold or hot here for that matter compared to other parts of the country. I'll check my plugs in a few weeks to see if there are any dark carbon deposits. Hopefully my jetting and mixture level is correct. | | |
