| | | Forums66 Topics128,125 Posts1,056,337 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | I'm going to be searching for spring bushings tomorrow for my 1949 COE. I'll probably start with NAPA. Anybody have any part numbers or good sources.
Thanks, Greg
1947 M15 Studebaker 454 4x4 1949 Chevy COE In the Stovebolt GalleryMore pix of the COE1950 Harley FL 1958 GMC LCF 455 3x2bbl 1961 Chevy C60 Tilt Cab 327 1966 Chevy C60 Tilt Cab 496 1961 Chevy K10 sb 292 1974 Harley FXE 1979 Chevy K10 sb 2007 Harley Streetglide I'm not that good but I'm slow
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | A spring shop like Eaton Detroit Spring or any other good spring shop more locally is a good start.
Grig | | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | Dunbar Spring in Phoenix and a couple of other Spring shops I've tried are no help. I need pins and bushings for the rear springs on a 1949 5400. Any leads or suggestions would be greatly appreciated.
Thanks, Greg
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Did you try Eaton Detroit spring? I have purchased some from them. Did you try NAPA for the pins and possibly bushings?
Grigg | | | | | Joined: Aug 2014 Posts: 216 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 216 | I bought new pins & then went to my local machine shop & had them make bushings fit my springs & the pins I bought. Pic #1 Pic #2
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | Toomany, where did you buy the new pins?
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Goob, I got my pins for my '50 5700 at Spectrac (spectrac.com) in Mesa/Gilbert, AZ. That was 4 or 5 years ago, so I don't know if they can still help you. Kent | | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | Thanks Kent. I'll check with them tomorrow.
| | | | | Joined: Aug 2014 Posts: 216 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 216 | Toomany, where did you buy the new pins? Eaton Spring.
