1 members (texczech),
51
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I opened up the 216 I obtained for my '46 to clean out the sludge and it's cleaning up nicely. One little problem...the screen on the oil pump has a few holes. Not huge, just the little squares turning into little rectangles. And just a few of them. The question: can I use it like that, or should I track down another one? | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Where are those little "lost" pieces going? Maybe right through the pump and into the bearings? I'd suggest fabricating a new strainer screen of some type. I've had pretty good luck using pierced sheet metal that's available on Ebay with small round holes, maybe 1/16" diameter or so, and forming/silver soldering it into a strainer. Jerry
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | This may be of assistance when you reassemble your pump. Harold Oil Pump Exploded View
Harold Is a restoration ever finished? | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | I opened up the 216 I obtained for my '46 to clean out the sludge and it's cleaning up nicely. One little problem...the screen on the oil pump has a few holes. Not huge, just the little squares turning into little rectangles. And just a few of them. The question: can I use it like that, or should I track down another one? Are there breaks in the wire, or are the gaps just different in shape?
| | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | 52Carl, it looks like breaks in the wire. I took it off to clean because it was caked with sludge. It was a running engine that was pulled out of the truck and still warm when I hauled it home, but I know it will work harder than it has in a long time when I get it in my truck so I want to do this right. I will check the screen in my old engine to see if it is in better shape. | | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | The inside of my 235 looks beautiful. Except for the #4 rod bearing and crank journal. I used the screen out of that one because it looks like new. | | |
